Thanks for the info,
First time I'm doing anything like this. We purchased the car a few weeks ago and I don't trust the douche bags we brought it off. They said they made a service on the motor but I think they only changed the engine oil and filters if that at all...
I pulled out the cabin air filter today and replaced that and boy was that filthy, hadn't been done for some time.
As well I changed the air filter and got the rear diff done (hopefully I have enough oil in there, yes it was dripping out-top plug)
Next week I will get to the front diff and gears, at the moment I only have NULON smooth shift 75W-90 will give this a go and when I get some funds then try the blend the you have mentioned.
What Subie are you driving too?
Thanks again for the help
No worries , definatly a good idea when getting a new car , might pay to remove the passenger side timing belt cover and have a look at the belt if you unsure on service history , its usually just the two 10mm bolts for the coolant overflow and another 4 holding the cover on that just slides off , you can at least get a rough idea how that looks and make sure there's no oil leaking onto it .
I've used the nulon before and its fine if there's no issues with the box , they can be pretty notchy and hard to get first etc that's when I'd look at the blend .
Yeh diff sounds good , that's full (.8litre) . It's good if you can do most of own servicing , the upper engine cleaner , and fuel additive can be bought off eBay at around half price or less .
I've been into the Subarus for awhile now and have a My 04 XT Forester . What have you picked up ?
