dazz
Downhill Dazz
You really are just begging for it!Was it you or the brake squealing?
I would ban you but it would delete your custom title which you have thoroughly earned.You really are just begging for it!
What method did you use to extract the piston, I've only seen it done with compressed air. Looks like you used a candle??As mentioned above, one of the pistons I replaced cracked on first ride. Maybe 15 minutes in.
Blob of hot glue on the end of another stick of glue.What method did you use to extract the piston, I've only seen it done with compressed air. Looks like you used a candle??
MacMooreyGyver at his finestBlob of hot glue on the end of another stick of glue.
Easiest method I’ve found. Especially in a caliper not connected and you don’t want to hook it up to a lever and pump them most out.MacMooreyGyver at his finest
Wasn't trying to take the piss, it's a cool trick.Easiest method I’ve found. Especially in a caliper not connected and you don’t want to hook it up to a lever and pump them most out.
I didn’t think you were.Wasn't trying to take the piss, it's a cool trick.
He mightn't be fast but by fuck he is rough.Wasn't trying to take the piss, it's a cool trick.
