Except it barely resembles the thing I like the most..Didn't think a day would come when I would become angry doing the thing I love the most.
From this you could probably get your freezer back up and running. With the left overs you have a new bike :whoo:Pfffffffttt......who're they kidding? It even looks freaked out by what it is...............
Additionally, the extra weight of the bike helps keep it really planted. We took on some pretty scary sections of trail on sight, and without exaggeration, we were quite shocked by just how capable the Levo is. The traction is impressive, and the bike sticks to its line no matter what the trail throws at you.
We found that we could look further ahead and worry less about what's in front of the wheels, letting momentum and grip carry us through sections we would normally expect to pinball. Perhaps the biggest surprise was how playful the bike is. 44-pounds sounds pretty sluggish, but once this bike gets up to speed, that weight translates into momentum that can be used for fun.
See a little root double just after a slow turn? 2 pedal strokes and you can launch over it.
See a big rock step in the middle of the climb? 2 pedal strokes and you can pop right up the face of it.
Want to hit the bonus lines off the side of the trail? No problem, as long as you keep momentum, the bike reacts surprisingly well to rider input, and can be pumped and jumped much like any other good trail bike.
Manualing the bike is however a bit of a chore, both due to the weight and the relatively long chain stays (compared to your normal trail bike).
With regards to power and range, our experience over 2 days showed that the Levo will allow you go much further and higher than you would with a regular mountain bike. This is of course one of the main reasons behind building these bikes in the first place.
However, if you use the bike in proper terrain, you'll soon find that you are getting a real workout too, especially if you leave the bike in Eco mode. The thing is, it pushes you to go further, and to try things you would normally ignore. We rode some fairly epic loops with significant amounts of climbing, and the bike came back from a 5-hour alpine adventure with 20-30% of battery power still left in the tank.
There are more reasons for using Eco mode than just range though: it is actually the most balanced setting, and the one that allows you to really go for the tricky stuff. Turbo mode is too powerful for most climbs, resulting in spin-outs, and even Trail mode has too much for certain situations.
Keep in mind that you are not throttling through stuff, as soon as you stop pedaling, the bike stops pushing, so getting through technical sections whether on the ups or the downs still requires good technique and fitness. You just get more trail for your efforts.
Darn toot'n. Rack and peanut steering all the way.If you're going to go that far... why not whack a Pinion gearbox in there while you're at it?
