I feel triggered. Or maybe validated? Nah,both.I was reading a bit of Vorsprung stuff after I messed up my knee recently. Could easily relate to my workshop routine too..
Yeah I get the lubrication but on a side point, if you fit one to a newish fork, there is enough fresh factory grease in there for 2 x Luftkappe installs.I feel triggered. Or maybe validated? Nah,both.
Or it could be the beers doing the thinking at this point…
Either way. All I know is, the Luftkappe (like all bicycle parts) requires *ample* lubrication when installing. Maple syrup may not be used as a substitute.
I'll go for another night ride this week to test it properly.If you have tested it under load and it's not jumping, you've caught it in time.
Absolutely you are the only one to have forgotten to switch the lever...New tyre day. Specialized Cannibal front and rear. I've run them before so I know how stout they feel but today on the first run I'm thinking jeeez, I really need to drop the pressure, these are transmitting everything and have limited grip on chunder. Stopped and did the trailside psst, psst, letting air out and continued. Then started thinking I needed less compression damping and more rebound to control it as it felt like it was bouncing off things....started to do my head in! Stopped again to start adjusting suspension....and there it is. Climb lever to climb. On a kitsuma shock when the climb lever is in climb it's like a hardtail. Easy fix lol.
It's a dateSee you back here in 100kms
Yes it does, but I bent up and drilled a couple of full length shims instead.Couple of washers under the calliper will fix that.
Pics please. I feel like you have impressively over complicated something and I would like to see whyYes it does, but I bent up and drilled a couple of full length shims instead.
The idea of a couple of M6 round washers doesn't sit well with me.
That is a shim of beauty
A lick of black paint and you could sell them - 200mm to 203mm conversion plates
