AM Carbonda FM1001 - Black Betty
386678
386679
When what looks like a dropper lever isn't a dropper lever:
386682
One extra cable doesn't clutter things up too much as long as the lengths are cut pretty precisely:
386681
Where the magic happens... Cable routing is pretty tight but works without issue, and who knew the font "Times New Roman" was still around?
386680
Frame - Carbonda FM1001 XL, 135mm rear travel.
Rear shock - RockShox Nude Deluxe Ultimate Supremely Superb Mystical Mega Wonder-shock (or however many other layers of hyperbole SRAM has piled upon their shock product names this week...)
Front shock/fork - Marzocchi Z1 Coil 150mm, X-firm spring, Grip2 Damper.
Handlebars - Spank Spike 800 Vibracore 31.8mm Diameter, 30mm rise. (Cut to approx. 770mm, but +10mm or so in use due to running single-clamp grips)
Stem - Diety Copperhead 50mm
Headset - Carbonda IS(something). Roughly ~1.5" upper and lower cups. Frame can be bought with internal routing that goes through the headset instead of the downtube.
Grips - ODI Elite Pro
Saddle - Ergon SME3
Seatpost - Vecnum Nivo 212mm, 4-position indexed (mechanical mechanism, air sprung)
Front brake - Hope Tech V4 with 203mm rotor
Rear brake - Hope Tech E4 with 203mm rotor
Cranks - Shimano XT M8100 with 30T chainring
Chainguide - One-Up
Chain - Shimano XTR 12sp
Pedals - Chromag Dagga
Rear shifter - Shimano XT SL-M8100 12sp (bar clamp type)
Rear derailleur - Shimano XTR RD-M9100 12sp
Cassette - Shimano XTR M9100 12sp
Front hub - Project 321 6-bolt Boost 32h
Rear hub - Chris King 6-bolt Boost/Microspline 32h
Front rim - 29" Nextie Premium Trail 40mm (36mm internal)
Rear rim - 29" Nextie Premium Enduro 36mm (29mm internal)
Spokes - DT Swiss Comp
Tyres - Maxxis Assegai 3C 2.5" EXO+ front tyre, Maxxix DHF 2.5" Exo (currently)
Tubeless Sealant - Stans Tubeless
Total weight - Don't know, don't care. Feels lighter than I expected
Extras - Black adjuster screws and pivot pins on Hope brake levers, Hope seat clamp, black Hope seat clamp nut and bolt, WolfTooth ReMote BarCentric dropper remote, Scott 3-position shock remote, Marsh Guard mudguard and "moustache", OneUp large pump and EDC tool, WolfTooth Master Link Combo Pliers and Lezyne Power Level XL tyre levers in dual OneUp pump holders.
When are you getting a trail fork and normal headset? :p
Trail forks mean flexy forks in my weight category. Not my cuppa.
What do you mean by "normal headset"? I don't geddit... :oops:
[EDIT: Wait - I do geddit. Better fix that spec from the copy and paste I pulled from the Sentinel PYR...] :p
leitch
Feelin' a bit rrranty
Ah that makes a bit more sense. I was like dude it’s a trail bike just run a 140 or 150mm fork if you don’t like the slack HA at 160.
kten
Ahh right….must pay attention. You’ve bought another but a bigger version. I was wondering why this looked a little more purposeful!
Hope it rides well, it looks great.
It’s meant to have a 140 fork IIRC, 150 is my intention (sag point is pretty deep with this coil/my weight), but no time to swap it tonight so the debut ride will be with a 160mm fork. Close enough, lol.
