This, also turn your rebound settings to slowest, makes it easier to push up and reattach once the deed is done.Pull harder.
So the 1200 x 600 stump that the vice is attached to is tilting off the floor and the screwdriver in the eyelet is bending, surely it shouldn't need that much force? Is there any other setting that might be causing it to stick? I've never come across this before.Pull harder.
How many clicks of compression are you running?So the 1200 x 600 stump that the vice is attached to is tilting off the floor and the screwdriver in the eyelet is bending, surely it shouldn't need that much force? Is there any other setting that might be causing it to stick? I've never come across this before.
I've turned the rebound dial fully clockwise as Zaf suggested and I've tried the propedal lever on every setting, is that what you mean?How many clicks of compression are you running?
Haha, got a winch?! Application of force fixes all problems!!So the 1200 x 600 stump that the vice is attached to is tilting off the floor and the screwdriver in the eyelet is bending, surely it shouldn't need that much force? Is there any other setting that might be causing it to stick? I've never come across this before.
Ha ha, that's exactly what I was doing in the vice, there was no way I was going to pull that shaft apart! Inverted the shock so the vice was gripping the upper eyelet, got a better grip on the body and it finally popped off. The only dumb question is the one you don't ask. Thanks Zaf.Haha, got a winch?! Application of force fixes all problems!!
Just out of curiosity, you are grabbing the air can and pulling? You're not pulling on the shaft eyelet or anything?
That made my night!!!Ha ha, that's exactly what I was doing in the vice, there was no way I was going to pull that shaft apart! Inverted the shock so the vice was gripping the upper eyelet, got a better grip on the body and it finally popped off. The only dumb question is the one you don't ask. Thanks Zaf.
Yep, absolutely, I've always wanted to end up as part of someone's Rotorburn signature and I guess tonight's effort would just about do it.That made my night!!!
Off you got to where you belong!! https://www.rotorburn.com/forums/showthread.php?257029-Confessions-from-the-fuck-wits
Glad you got it fixed hey!
