Can't separate Fox RP23 air sleeve
4wdphil
I must be doing something wrong here but I've let the air out and unscrewed it as far as it will go but it won't separate. There is a tiny amount of movement between the two sleeves but nothing more than that. Any ideas? It's a boost valve model if that makes any difference.WP_20170227_19_59_37_Pro[1].jpg
4wdphil
Pull harder.
So the 1200 x 600 stump that the vice is attached to is tilting off the floor and the screwdriver in the eyelet is bending, surely it shouldn't need that much force? Is there any other setting that might be causing it to stick? I've never come across this before.
気が狂っている男
How many clicks of compression are you running?
Z
Zaf
Guest
Haha, got a winch?! Application of force fixes all problems!!
Just out of curiosity, you are grabbing the air can and pulling? You're not pulling on the shaft eyelet or anything?
4wdphil
Ha ha, that's exactly what I was doing in the vice, there was no way I was going to pull that shaft apart! Inverted the shock so the vice was gripping the upper eyelet, got a better grip on the body and it finally popped off. The only dumb question is the one you don't ask. Thanks Zaf.
Z
Zaf
Guest
