freddofrog
What is the simpliest/safest way to control the temp of these heating elements? It’s in a Behmor coffee roaster and the control panel only allows increments of 25/50/75/100%. I need it to be infinitely variable.
I was thinking of setting up a timer to pulse the voltage which is how it currently works. Eg 50% power cycles the elements on/for 7.5sec at a time. While I have created timing circuits based on a 555 IC timer chip it is still a relatively complex solution.
Other roasters have used Solid State Voltge Relays (SSVR) which seems to be a glorified dimmer switch on steroids but given these seem to be very hard to source I’m thinking there must be another way. But it does seem easy, simply connect inline to the heating elements and mount on a heat sink.
And I’ve pulled apart a few toaster ovens and bar heaters and they work on some weird variable resistor trim pot thing which I can’t figure out.
Ideas?
http://www.behmor.com.au/
Ideas?
