wespelarno
I recently purchased a set of aktimate mini speakers and they are behaving strangely. They emit a static hiss (more than normal amplifier hiss), a medium frequency buzzing sound and are picking up and quietly playing fm radio, specifically fm 102.3 (In canberra, ABC radio). I have tried the following things with minimal success:
Rewired all electrical items in my room-no change
Used a powerboard that trims excess frequencies in AC current-no change
Using shielded wire to connect the master and slave speaker-buzzing and hiss reduced marginally
Checked all power sockets in house for correct wiring-all sockets correct
Unplugged all power appliances in house simultaneously to check they aren't emitting radio interference-no change
There is little pattern or consitency regarding speaker position and buzz. I've moved the speakers all around my room and house and get varied results with no apparent logic. Often being placed in the same location at different times gives different results.
I disconnected the slave speaker from the master speaker and removed the input cables. Connected to a frequency trimming powerboard the master speaker still picks up and quietly plays fm radio.
I wrapped the speakers in alumium foil (home made faraday cage), and achieved blissful interference free music. Obviously this isn't a long term solution. I have been unable to recreate the situation in the store I purchased the speakers from and they assure me the system is functional.
The system consists of a master speakers with a built in digital amp, connected to a slave speaker.
So, who has suggestions as to what next?
