i was looking at the saints as a dual ring option, and i must be wrong but i thought the advantage of long cage was to take the slack out of the chain when on the granny crank ( which i don't use). Have i missed somethingHuh, what the hell do you want Saints on a XC bike for? Also can you run a short cage with a 48t ring?
The question was more 'why do you need heavy duty cranks like saints on a xc bike that will never need to cope with that level of abuse?'i was looking at the saints as a dual ring option, and i must be wrong but i thought the advantage of long cage was to take the slack out of the chain when on the granny crank ( which i don't use). Have i missed something
Yes, the long cage not only takes up slack from granny but also the largest ring to.i was looking at the saints as a dual ring option, and i must be wrong but i thought the advantage of long cage was to take the slack out of the chain when on the granny crank ( which i don't use). Have i missed something
Medium cage - 2x9 set up (*note with this setup you might be able to run short cage depending on the ratios you have ie. 28-32 front, 12-25 rear. Or you might have to run long cage if your ratios are crazy wide.)
you do realise if you take the outer ring off xt's you get dual ring? just because it comes with 3 rings doesnt mean you have to keep all 3 rings on itThis is the main reason i want to get a dual ring. I know he saint is overkill but given the short cage i figured it to be better to opt for a saint or a stylo 2.2
Im with him^, the New SLX, ohh you should poll this thread with all the options and see which one comes out bestthe new SLX from chain reaction cycles. cheap, strong, light, and look good to.
mmm, it just seams like a waste to buy a 3 ring and remove one. Though this might be a good option i could do that and have a bash guard on instead of the top ring. In doing this it gives me the option to ditch the short cage and move to a 3ring with a long cage.you do realise if you take the outer ring off xt's you get dual ring? just because it comes with 3 rings doesnt mean you have to keep all 3 rings on it
i never said i wouldn't do it, i simply never thought of it ( stupidly!)you do realise how much more saints cost then xt's do you? i run xt's with 1 ring, was it a waste to do that instead of using 3 rings, hell no
what you want to do is just stupidly impractical when you can buy something cheaper and better for what you want but you wont do it because you dont want to remove a chainring
