Has anyone ridden both?
I can get the Teocali for $250 cheaper and it seems to have better spec drivetrain, brakes and wheels. Reign has better shocks but I've read some bad reviews about the hubs and can't find anything on the rims.
The Teocali felt pretty fun but I'm a bit suss on the rear suspension performance/durability (googled reviews give mixed feedback).
I've done the carpark test but that obviously doesn't tell too much...
FRAME
Sizes S:15, M:17, L:19
Colors Black
Frame ALUXX SL FluidFormed™ alloy Maestro 6.0” travel
Fork Fox 32 FLOAT RL w/ 15QR axle and Tapered Steerer, 5.9”/150mm Travel
Shock Fox Float RP2 w/XV sleeve & boost valve
COMPONENTS
Handlebar Giant Connect oversize alloy 670mm x 25mm rise
Stem Giant Connect oversize alloy, 4 bolt, 8 degree
Seatpost Giant Connect oversize alloy micro-adjust 30.9
Saddle Fi’zi:k Gobi XM w/Manganese rail
Pedals N/A
DRIVETRAIN
Shifters SRAM X-5 trigger shift 27 sp.
Front Derailleur Shimano SLX 9 sp direct mount
Rear Derailleur SRAM X-7 9 sp
Brakes Avid Elixir 1 hydraulic, w/7” front & 6” rear 6 bolt rotors
Brake Levers Avid Elixir 1 hydraulic
Cassette Shimano HG30 9 sp 11-34T
Chain Shimano HG53 9 sp
Crankset Shimano M542 22x32x44T
Bottom Bracket Shimano BB71, press fit
WHEELS
Rims DT 465D double wall, eyeleted, alloy 32H disc
Hubs Fr: Giant Tracker sealed cartridge 15QR | Rr: Shimano M475 9sp disc
Spokes 14/15G butted stainless
Tires [F] Maxxis Minion DHF 26x2.35 [R] Maxxis High Roller 26x2.35
OTHER
Extras Shock pump
Sizes: Extra Large Frame
Frame: New Mongoose FreeDrive W/ 150 mm travel, tapered head tube, ISCG-05 mounts, and replaceable hanger
Fork: Rock Shox Sektor RL 150 mm travel, Solo Air spring, lockout, rebound and 15 mm Maxle Lite thru axle
Rear Shock: Ario 3.2 , air spring, rebound and lock out, 200x57 mm w/ 19x8 mm hardware
Crank: FSA Comet 27/39T alloy
Bottom Bracket: FSA MegaExo external bearing
Shifters: SRAM X.7 2x10 speed
Speeds: 27 Speed
Front Derailleur: Shimano SLX
Rear Derailleur: SRAM X.9 medium cage
Wheels Size: XL
Tires: Kenda Excavator 26x2.35 front / 2.1 rear Dual Tread Compound, folding bead
Brake: Avid Elixir 3 hydraulic disc w/ 185 mm front /160mm rear rotors
Handlebar: Kore Torsion Race Riser Handlebar 710 x 31.8 x 20 rise x 5 deg BB Black
Stem: Kore B-52 0 deg. K34 Stem 65x31.8x28.6 BB Black
Headset: FSA ZS Taper w/ACB bearigns (1.125" upper 1.5" lower).
Brake Levers: Avid Elixir 3
Spokes: 14g Stainless
Grips: Mongoose Lock on
Saddle: Kore T-Beam, 6061 forged alloy rail
Seat Post: Kore T-Beam / I-Beam 6061 Seatpost 31.6 x 350 Satin Silver head, zero offset, BB Black shaft
Seat Clamp: Alloy w/ QR
FRAME
Colors Black
COMPONENTS
Pedals N/A
DRIVETRAIN
WHEELS
OTHER
Extras Shock pump
Speeds: 27 Speed
Wheels Size: XL
