loc81
Yep it's NWThat is MonoVeloce.
Just covering the basics mate, but are you 100% it is a NW ring? Blackspire make the MonoVeloce rings in both NW and standard tooth profiles.
Ahh good Blackspire it is , you will clearly see the difference between wide and the narrow teeth on the ring, now make sure you got the chain on the correct wide/narrow slots.Yep it's NW
Getting the tooth alignment wrong is pretty damn obvious though, its not like it kinda fits, its worse than having a 3/32 chain on a 1/8 sprocket.Jacko69 might be onto something here as you are wrong in the believe that there is only one way for the chain to sit on the NW, there are two.
As suggested you must make sure that the wide tooth on the NW ring matches the wide gap in the chain and the narrow tooth matches the narrow gap on the chain.
If you are out by one tooth/slot the NW will not work as designed and might cause the chain to come off in certain conditions.
If all else fails get a Blackspire front NW and be forever happy.
Oh ok, yeah could be. I assumed it was short because the op said his was mid, and it's definitely longer than mine. Came spec'd on a complete bike I bought so I don't know for sure.that looks like a mid cage to me !
IMO....chain is too long and your B-screw is too far out. But the chainline is perfect and there is no need to swap the chainring unless it is worn out.3 pics here for all y'all- high gear, low gear and a chain line view from 5th gear. See what you think.
Not sure if you have dealt with the SRAM stuff but you can push the cage waaay forward and toggle a lock out to keep it there, so you can remove your back wheel.Oh ok, yeah could be. I assumed it was short because the op said his was mid, and it's definitely longer than mine. Came spec'd on a complete bike I bought so I don't know for sure.
To the OP, did you see if you could manually push the derailleur any closer to the bottom bracket? Or is it fully extended in the 42 tooth?
Bad ,bad ,expensive bad , do not run your chain to short if you value your derailleur.Not sure if you have dealt with the SRAM stuff but you can push the cage waaay forward and toggle a lock out to keep it there, so you can remove your back wheel.
I'd be happy to remove a link or maybe 2 to try resolving the issue but what are to consequences of a chain that is too short?
Yeah mines an x9 as well (as pictured earlier) I'm familiar with the lockout, it's very handy. What I'm asking though is if your derailleur is close to fully extended when it is in the 42 tooth gear, probably to the point where you could push the lock in, because it should be.Not sure if you have dealt with the SRAM stuff but you can push the cage waaay forward and toggle a lock out to keep it there, so you can remove your back wheel.
Implying it's possible to put the chain on the wrong teeth on a NW ring?now make sure you got the chain on the correct wide/narrow slots.
Firstly, I appreciate all the replies here!Yeah mines an x9 as well (as pictured earlier) I'm familiar with the lockout, it's very handy. What I'm asking though is if your derailleur is close to fully extended when it is in the 42 tooth gear...
Yes it is possible,wrong slotting the chain on the ring and your nice NW becomes more like a normal chainring or worse.Implying it's possible to put the chain on the wrong teeth on a NW ring?
Yeah no prob, Just re-read my previous post and it isnt very clear (its hard to explain things over the net)Firstly, I appreciate all the replies here!
I'll post another pic or 2 this afternoon with the cage at full limit (beyond that locking mechanism) and just at that picking point.
All this info I've been partially aware of in the past, but I've never been keen to test the friendship with my chain!Yeah no prob, Just re-read my previous post and it isnt very clear (its hard to explain things over the net)
Im assuming your cassette is now 11-42. That is a very wide ratio. As such, you need a much longer chain when you are in the 42 tooth than you do when you are in the 11 tooth..
Does it peel off whilst you have the power on, or just fall off over bumps when you are not pedalling ? If the former, frame flex could play a part maybe.Well the first lap was good but dropped it on the second- ironically not on the big bumps but at the tail end of the sprint out of Jurassic Park! Go figure.
Given that I can lose 3 more until I reach it's limit, do you see much harm in removing 1 more?
Not sure if this was answered further on but it can be adjusted. The plastic cap inside the "roller bearing clutch" part can be pried out, and while it looks like you need a massive torx wrench to adjust it, you can also use an 8mm hex key. Careful when adjusting it as a small turn can yield a big change, and you can have too much!As for clutch tension I'm not aware that you can adjust it on SRAM derailluers?
This is my reservation about the whole 1x10 set up with a 36 as the biggest gear. I don't often find myself climbing hills that I can't spin up at the moment in my 32x36 and I don't really want the hassle of changing to a 2x set up when I am going trail riding or a whole day epic.Ran out of gearing with my 1x10 (32-11/36) for the first time at the Convict 100 on Saturday. Sitting in a bunch on the dirt roads I spun out the 32x10, and then could have used some slightly lower gearing than 32x36 on the way up some of those hills! Still, it's a fairly uncommon situation to be in, but I'm surprised it actually happened!
