StanzaRallyMan
A while ago I bought some 2006 Reba Dual Air Forks off ebay. Installed them and everyhing worked really well. Thought it was about to to give them a service so pulled them apart. Everything went well. Put air in the positive and negativ chamber and all good. Tested on the road and everything working well, nice and supply with good travel
This afternoon, took all the air out of the negative chamber and then the positive chamber with the intention of meausirng actual travel to work out how much camber pressure I need to set correct sag. Put 100psi in the positive chamber and 100 in the negative. Now the suspension wont move! If I ride around the back yard the forks wont move. If I jam on the front brake it moves but makes a clunking sound on initial movement.
Not sure what is going on. Any suggestions?
