singlespeedfreeride
Cycleworld
ok, ive got about a 50m run in from under a 10ft cliff, then some flat ground. ive already decided to drop the cliff or roll in from under it. anyone got some ideas of what to build one there using nothing but dirt?
or be really different and make it a step up! 10 feet is doable!try a step down jump or something,
I would do this. It pics up your skills in cornering.build like a berm track with little pumps in the middle of each berm or even jumps from berm to berm, those sort of things are always fun
Is that because you don't want people to see you building it? Sounds a bit shifty (illegal)....tell me if im wrongyeah i probably will. ive decided to build 2 lines. one snaking down the hill, one going straight down into the flat
im planning making some tight high speed berms and some tight flat corners to sharpen my drifting skills
i might go start the pump track tomorrow since there probably wont be many people out
Yeah, that's what I'm thinking now too ...Is that because you don't want people to see you building it? Sounds a bit shifty (illegal)....tell me if im wrong
