Yeah they're all pretty much the same. They all use schraeder fittings.I need to get a shock pump for my bike. My questions is:
- What shock pump do you recommend based on your usage of them?
- Do all shock pumps fit different forks and shocks?
- Are all pumps the same? Does it matter what one I get?
I could easily agree with that - I haven't scrutinized it to the T but the Rock Shox & Giant pump looked very similar and felt the same to use. Not forgetting that the Giant one is now nearly 2 years old any differences would probably be attributed to some "cosmetic" changes.of the 'Branded' shock pumps like Marzocchi, Rock Shox, Fox, Giant and others are all made by a pump manufacturing company from Taiwan named Giyo . The Giyo pumps can be bought for a good deal less than the 'Branded' pumps but they are exactly the same pump just without the 'Brand' painted on them.
Do you mean the hissing noise of air escaping when you unscrew it? That's usually air escaping from the hose attached to the pump and not the actual shock i may be wrong though.It supposedly has a 'special' removal system that stops this, but I'm always finding myself pumping 10-15psi over the pressure I want to counter for the loss when removing the fitting.
That's just the air from the shock filling the volume between the shock valve and the valve in the pump. That volume varies between pumps, but as far as I can see the Shock X doesn't leak or open the shock valve when the purple dial on the head is screwed out.Yes, the hissing noise is there, and I realise that it's normally just the sound of the air escaping the hose/fitting etc, but if you immediately screw the pump back on, the pressure will be 10-15 and sometimes 20 psi lower than the level it was initially inflated to.
Yeah, I have to do that when I pump up my dual air rear shock which is even worse as the chamber is even smaller!My trick is to screw it on a bit past the point where it first registers on the gauge. And then when un-screwing I try to undo it to a certain point and then start undoing it a lot quicker (primarily over that magic release point) which seems to minimize the pressure loss quite a bit.
