VicDH Series rnd2 Mt Major, Shepparton
http://vimeo.com/31940267
just starting to get into filming, so any constructive criticism is appreciated.
Enjoy
Cheers Tom
Great effort, you've got some good content there. Just a few things I would suggest:
1. Use a tripod if you are going to be using the zoom quite a bit.
2. Cutting to the tempo of the music is great, but don't let it dictate the pacing of the edit. I felt like a lot of the cuts at the start were way too fast.
3. Less panning - its better to have a locked off wide shot that shows the same field of view. Ideally you would be able to intercut with close-up shots.
4. The title design is awesome, but you need to hold each bit of text for long enough for the viewer to read. Maybe better to start with slower music while you establish everything?
5. Break up the types of shots you are using, ie try cutting between wide, medium and close-up shots. Cutting from a medium to a medium shot results in jump-cuts that don't always work.
Just my 2c, shooting biking action is actually very challenging and hard to get right.
