Off the online specs it looks like M445/447 which is pretty entry level.
Without more info on what you don't like about them it's hard to say what brakes to recommend. Is it brake fade, not enough stopping power or modulation that you are annoyed about?
It probably depends on a number of things but here goes...
- $120 per set: Deore M615. These things are the entry level standard and I personally use them on my bike. Does what a brake should do no worries.
- A little bit more: SLX Pretty much the same with a little more adjustment and some weight reduction.
- A little more again: XT more features but roughly the same as SLX. Some swear it has better modulation and power, some say it's the same just more adjustment. I can't say because I've never tried SLX before.
- $280 a set: Zee: This is what you go for if you are heavy or require heaps of braking power or doing some serious riding that loads the brakes (i.e. lots of step downhill for long runs). I've only ever used these on a loaner DH bike and I can see why people love them so much. For XC riding I think I would prefer something a little less powerful. They are also a bit heavier than the SLX/XT models.
- Saint (no idea what the difference is?
Suffice to say, don't go for avids.
to take away the vagueness of "extra features"
deore = perfect - crc has 10% off these now so you can get a set for about $90
slx = 20 bucks more and you get toolless leaver reach adjust that you dont need and you can do with an allen key in 30 seconds on deore
xt = 20 bucks more and you get caliper bite point adjust that doesnt work and ice tech brake bads that dont really do much either.
the calipers and leavers are identical in design. if you did a blind test i couldnt tell the difference, neither could you and neither could a shimano sponsored rider.
if you think XT has more power its only because the dude with the XT brakes have them setup nicer and better maintained.
