.:ROBBO:.
Some Background first.
Current set up- 2004 Demo 9. 2010 Boxxers(Bought second hand but recently serviced and im pretty sure all upgrades were done), Med spring, flat crown, Truvativ Holzfeller 50mm Direct Mount Stem and Pro Atherton Star Series 745mm/5*up/9*back/20mm rise bars.
Previously it was basicaly stock with 04 888s, stock Marz direct mount and Deity Twenty14 Bars 710mm/50mm rise.
Rear is a 6way swinger with a 500lb spring. I weigh 80ish KG.
I run the bars pretty much flat. Im almost convinced I have the forks tuned fairly well but im only going by what I've read in the manual and on the net. The current set up has lowered the front at least 50mm or more. Since going to this set up the bike is real twitchy/unstable cornering. Its way more noticable on a big sweeping corner if you touch the front at all. Its hard to explain but the bike just becomes really unsettled. And getting over the bars just makes it worse brakes or not. For those that know Kenilworth it was really noticable on the big RH sweeper comming out of the forest before the LH switch back down the bottom which is fairly washed out at the moment.
Before changing the set up the bike felt pretty much dialed. Except it was heavy up front. But definitely corned a lot better.
Have I gone to low in the front? Going by the pic the head angle looks to be a lot steeper but I have not measured it. Wrong choice of bars/stem? Or is it more likely my fork set up?
Dont bother replying if all your going to say is I should have bought Fox 40s. They both have their pros and cons.
Current set up-
Old set up but with different bars-
Current set up-
