kwikee
Tonight I have converted my Syncros wheelset to tubeless with Maxxis High Roller 2 and Ardent tyres.
The question is often asked "why convert to tubeless?", and one of the reasons given is to save weight. I was curious as to exactly how much weight there was to be lost, so checked some stuff as I went and this is the result.
Wheels as they were on the bike, with Icetech 180mm discs, XT cassette and Maxxis Ardent 2.25 single compound on the front, Ikon 2.2 single compound rear:
front: 1891g, rear: 2321g, total 4213g.
Front tube:139g, Ardent 667g.
Rear tube: 197g, Ikon 552g
I removed the Syncros rim tape, put 2 layers of Stans yellow tape, then the Stans rim strip. The front Ardent was put on the back, and a new High Roller 2 single compound 2.3 (857g) fitted with 2 scoops (nominally 120g) of sealant.
The Ardent was fitted to the rear, with 1 1/2 scoops of Stans.
Front: 2129g, allowing for extra weight of HR2 over Ardent (190g), this is still a gain of 48g. I can only assume the Stans is slightly heavier than 60g/2oz.
Rear: 2391g, allowing for extra weight of Ardent over Ikon (115g), this is a loss of 45g.
Total: 4520g vs 4213g before.
Given I have added 305g of tyre weight, the nett weight gain/loss was almost neutral. In other words, in this case the conversion neither saves nor loses weight, however this bike had pretty light tubes. You could also use a bit less sealant, depending on your tyres.
Hopefully this is helpful to someone!
