hakka
I'm having trouble getting some pivot bearings for a 2015 Trance. The bearings are in the upper part of the rear triangle, where it attaches to the rocker arms. They are labelled 6900v-rs, they are a non standard 6900 bearing, the outer race extends 3mm on one side and has a 1mm x 1mm flange on the end so it sits at the right depth in the bore.
The LBS ordered a bearing kit to suit my bike but these weren't included. Whoever they're talking to at Giant doesn't seem to know whats going on.
I've also been in contact with DIYMTB to see if there's an Enduro bearing that will work, but they haven't seen one like this or heard anything about it. They are still chasing it up to see if they have anything suitable.
Today at the LBS I was looking at the Trances on the floor (2015 and 2016) and they all have a slightly different setup, on mine the outer race of the bearing and a little bit of the bearing seal is visible around the bolt head (see 1st pic). The Trances in the shop have a different bolt with a larger head, none of the bearing is visible. I'm wondering if its just a different bolt or if maybe there's a different bearing setup underneath the bolt head.
Just wondering if any Trance owners have had any experience with these bearings, and if you have the larger bolts do you know if the bearing and rocker are the same setup as mine?
