yeah that was setup for a camping trip, it did hit the fork a few times (well a-lot actually)Good to know! Just a quick question with that set up of yours. What happens with that front waterbottle once your forks compress? Is there enough room there?
+ many+1that Ventana is friggin gorgeous!!!!!!
Geez Hifi, when I saw you'd replied to this thread, I got all excited expecting to see pics of your new single speed.+ many+1
Nice. Should be a light build. Go for a carbon rigid fork. Use your arms, legs and tyres as suspension.Thought I'd post a progress pic of my build. Forks are a loaner until I work out whether to run rigid or susp. It's my 'mucking around' bike that I'm trying to keep light but robust.
All good things come to those who wait. Well, that's what I keep having to tell myself...Geez Hifi, when I saw you'd replied to this thread, I got all excited expecting to see pics of your new single speed.
Noice, very noice. Are you running your tyres tubeless? The first pic makes it look like the front wheel is using a UST valve, so I'm assuming you are.Salsa Selma 20", Pro XCR Carbon fork, Easton monkeylite bar, ea70 stem, Stans Arch rims, Hadley SS hub rear, King front, Juicy 7s, Middleburn ISIS cranks with Uno, FSA BB and Bushnell EBB. Truvativ seatpost and the fantastic Charge Spoon saddle. 959 pedals. 9.64kg.
I'm using a cheap tape. It comes from Bunnings, is made by Norton, found in the paint section, Outdoor masking tape. $4 for 50mtr. I've used it in a few wheelsets now and it's been great. 3 layers does the job - it's quite thin so this doesn't add weight. A bit of sealant and they seal without a compressor. Very happy with them.Noice, very noice. Are you running your tyres tubeless? The first pic makes it look like the front wheel is using a UST valve, so I'm assuming you are.
Anyways - reason I ask is that I have the exact same and was wondering if you've needed to do anything out of the ordinary or whether you have any advice on setting them up? I've sealed my rims with filament & electrical tape, have nailclippered the little rubber irregularities off the beads and am running them with tubes for a while so they get very well acquainted with the rims before I take the leap. Anything else I need to before I break out the Stan's bottle?
Feel free to PM me if you don't want to clog the thread up.
Agreed - that's why I put a layer of 3M filament tape down over the spoke holes first. Light, doesn't stretch and lays the perfect base for the electrical tape. Thanks for the heads up on the outdoor masking tape.in my experience the electrical tape glue isn't resistant enough to the water that comes in through the nipple holes.
I ran a 32:18 last year a 32:16 might be a little to small for some of the pinches later in the daySo on a completely separate topic, the Angry is coming up. Any suggestions on gearing?
I ran 33:17 (26") at the Dirt Works with no problems. But I hear that there's hella climbing to be done at Mogo and you're likely to be coasting anyway on all the sections where you'd run out of pedals.
32:18?
