willsy01
Well it's taken a while, but I finally finished this thing during the week.
Frame - 2012 Commencal Meta AM (courtesy of BigHair, thx bud)
Rear shock - 2013 Float CTD (Chris Kovarik's!! Hopefully some of his skill was transferred)
Front shock/fork - 2013 Float CTD 150mm
Handlebars - Easton Haven 711mm
Stem - RaceFace Turbine 50mm
Headset - Hope pick 'n mix
Grips - ODI Oury lock on
Saddle - Fizik Gobi
Seatpost - KS Lev (thx Al @ Pushie)
Front brake - M785 XT on a 203mm rotor w/Goodridge lines
Rear brake - M785 XT on a 180mm rotor w/Goodridge lines
Cranks - M785 XT w/34t RaceFace narrow wide ring
Chainguide - MRP AMG
Chain - XTR 10sp
Pedals - M985 XTR Trail
Front derailleur - nil
Rear derailleur - Shimano ZEE with what I think is one of the last Gore cable kits
Front shifter - nil
Rear shifter - M820 Saint
Cassette - XT 11-36 10sp
Front hub - Hope Pro II Evo
Rear hub - Hope Pro II Evo
Front rim - Stans Flow EX
Rear rim - Stans Flow EX
Spokes - Black ones
Nipples - Also black ones
Tyres - Hans Dampf 2.35
Tubes - Liquid latex
Total weight - More than an 18mm spanner, less than a Lada Niva
As mentioned above, I picked up the frame from Hamish back in July. I agonised over colours for a while then took it to Chris at Craved Coatings......then ended up picking something very different. He did a brilliant job despite having an epic queue of jobs to get through.
All the bits were sourced over some months. The head tube cable routing grommets and neoprene mudguard are probably worth more than gold based on weight. So all the bits were sitting in their boxes ready to go......frame was powder coated......then came the slump.
I'm not sure what happened. Riding just wasn't appealing to me and the thought of building the bike was just a chore, not something enjoyable like it should be. I'd convinced myself that I wouldn't build it until I did the frameskin and the idea of measuring that then cutting it to fit was even more off-putting. It didn't help that a lot of powder coat needed to be filed off for the frame to go together which was a lesson learnt.
Eventually, I just gave up on the frame skin and built the thing. The internal cable routing is a complete bitch, but it's very neat. Very little of the outer or brake line can be seen. Very happy with the end result, although i've not been able to take it for a proper spin. Yes, the white forks don't quite fit but i'm not rich enough to buy new ones. Anyway.....here it is:
Saddle - Fizik Gobi
Chain - XTR 10sp
Front shifter - nil
Spokes - Black ones
