Holy dooly! What is that - like 2m long!
Bit over a meter maybe a meter and a half. It's really easy to over estimate the length of a snake for some reason/ I think snakes have the own version of the pink bike ruler:single_eye:
I'm not a fan of snakes. Frankly I couldn't tell them apart.
So is it worth re-capping what to do if you get bitten out on the trail ?
I've read about "keep your heart rate low" ... but chances are you're pumping with adrenalin, so you get back on the bike and ride out ? or walk ? isn't riding more efficient than walking ?
Apparently those "snake bite kits" are crap and you should just get to a hospital. Whats to go ?
Some general advise noting that I'm not an expert and If you ride in the bush and haven't done a first aid course you really should.
The venom travels through your lymphatic system. This basically gets pumped around by moving muscles therefore it's vital to keep the victim as still as possible. the more you move, ie trying to ride or walk out, the faster the venom will get pumped around your system.
You should try and remain calm. Remember more people die in Australia from Bee and wasp stings than they do from snake bites, probably due to effective first aid. A lot of bites don't show any sign of envenomation at allso stay calm but treat it.
You should carry a compression bandage.
Starting just above the bite you want to bandage down the limb (Although some people are now recommending just starting at the tips of fingers or toes and bandaging up) then all the way back up. You want the bandage firm but not cutting off the blood. The lympth system is low pressure and close to the surface, they say about the same tightness as you would for a sprained ankle or wrist.
If you have a pen mark the bite site on the bandage (that way the hospital can just cut a bit away to do a venom test rather that take the whole bandage off) and also the date and time.
There is a good bicycling australia article about snake safety here
http://bicyclingaustralia.com/node/145
The only bit I'd disagree with is "If at all possible, identify the type of snake that did the damage. Note colour, size, shape of head and so on." That's all well a good but colour especially is next to useless in IDing a snake and the doctor in casualty is likely to have as little idea as you so by the time you convince him it was a king brown (or more properly call a Mulga, a member of the black snake family) 100s of kms outside there actual range the venom detection kit will have told him it was Copperhead. Sure grab a photo and and description if you can do so with out putting you or the victim in anymore danger but I'd rather concentrate on getting the bandage on and the ambos called.
and a good first aid article here
http://www.workingwithwildlife.com.au/downloads/WwW-First-Aid-Sheet.pdf
