Agostino
Frame - FACT IS 9m carbon front triangle, 29" geometry, M5 alloy rear triangle
Rear shock - Custom FOX Float CTD Evolution with AUTOSAG
Front shock/fork - FOX Float CTD Evolution 29, 15mm thru-axle, 130mm travel
Handlebars - Specialized XC Mini-Riser, 7050 butted alloy, 720mm wide
Stem - (Not Shown) Thomson 90mm +/- 10 deg
Headset - 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
Grips - Specialized Sip Grip
Saddle - Specialized Phenom 143mm
Seatpost - Thomson 30.9 Layback
Front brake - Custom Avid Elixir 5 SL, HS-1 rotor 200mm
Rear brake - Custom Avid Elixir 5 SL, HS-1 rotor 180mm
Cranks - Custom SRAM S-1250, 10-speed XC Trail double w/ alloy guard
Chain - KMC X10, nickel plate, reusable Missing Link
Pedals - (Not Shown) Shimano XT Clipless
Front derailleur - SRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
Rear derailleur -SRAM X9, 10-speed, mid cage
Shifters - SRAM X7, 10-speed, aluminum trigger, w/MatchMaker clamp
Cassette - SRAM PG-1030, 10-speed, 11-36
Front hub -Specialized Hi Lo disc, sealed cartridge bearing, 15mm thru-axle, 32h
Rear hub -New Specialized Hi Lo disc, 4x-sealed cartridge bearing, 142mm spacing, 12mm thru-axle, 32h
Rims - Roval 29, alloy disc, 26mm wide, 32h
Spokes - DT Industry, 2.0 stainless
Tyres - F Specialized Purgatory Control, 2Bliss Ready, 60TPI, aramid bead, dual-compound, 29x2.3", Specialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29x2.3" R
Tubes - Tubeless
Total weight - 12.6kg ish?
Tubes - Tubeless
