billymtb
I've re-installed a new olive and barb on my SRAM guide 4 times to try and stop a slow weep from between the compression nut and the hose. Thought it was because my line cut wasn't straight enough so bought a hydraulic hose cutter on ebay and did everything perfectly including putting some DOT compatible grease on the barb, olive and nut.
I'm using a torque wrench with crowfoot fitting at 90 degrees and going to 5nm.
Barb is flush with the cable
Pushing in the hose whilst tightening
Spray alcohol near the nut numerous times to make sure the weeping isn't from over spill.
Cotton bud lightly inside the lever to remove any contaminants.
Any one have any ideas? This is what else I'm coming up with so far.
1). Too much torque? What happens from over tightening? I feel the compression nut engage but I have to tighten quite a lot after that but still stopping at 5 - 5.5nm and on the old fittings that I cut out to redo the bottom of the olive is significantly pressed in to the outer hose so perhaps the sharp edge is cutting through the hose a tiny bit?
2). Barb screwed in too much? I make it flush with the cable then a teeny tiny bit more to make sure it is flush and flatten any high spots.
Can anyone with SRAM Guides let me know how much thread is showing on theres, a picture would be greatly appreciated
