PeterRidesBikes!
Cannon Fodder
Only got like 24hrs ago. Awesome to ride. Soz it not my photo but i aint got the pics on the comp yet
Description / Specification:
FRAME
Specialized 100% Cr-Mo, double-butted HT/DT, externally relieved HT, disc mount, 6mm offset horizontal drop out for 26" wheel w/ single- and multispeed hardware, disc only
REAR SHOCK
FORK
Marzocchi DJ3, 80mm, Cr-Mo steerer, 32mm Cr-Mo stanchions, magnesium lower, fixed rate catridge damping, coil/mcu w/ preload adj., "stiff" spring
HEADSET
Tank FX, 1-1/8" threadless w/ hollow bolt
STEM
Specialized aggro, 3D forged/CNC, 4-bolt, 35mm length
HANDLEBARS
Specialized alloy riser bar, 31.8mm, 55mm rise, 680mm wide, 8 degree back sweep, 8 degree up
GRIPS
Fuse BMX, single compound, closed end, 140mm
FRONT BRAKE
Avid BB5, mechanical disc, caliper/adapter w/ 160mm G2 Clean Sweep rotor
REAR BRAKE
Avid BB5, mechanical disc, caliper/adapter w/ 140mm G2 Clean Sweep rotor
BRAKE LEVERS
Avid FR-5, alloy, two-finger, linear pull
FRONT DERAILLEUR
REAR DERAILLEUR
SRAM X-5, short cage
SHIFT LEVERS
SRAM x4, 8-speed trigger
CASSETTE
SRAM PG-830, 8-speed, 11-28t
CHAIN
KMC X8 w/ reuseable Missing Link
CRANKSET
Fuse tubular heat treated Cr-Mo 3pc.
CHAINRINGS
34A w/ poly bash guard and Specialized ISCG chain guide
BOTTOM BRACKET
Fuse Euro, alloy cups, 4x cartridge bearing
PEDALS
Specialized alloy platform, 9/16"
RIMS
Specialized/Alex P.Disc AM, double wall disc w/ eyelets, 36h
FRONT HUB
Specialized, forged alloy, high/low flange, 36h, nutted 3/8" axle
REAR HUB
Specialized Hi Lo, forged alloy, double sealed, ground race, cassette, nutted with 3/8" axle, 36h
SPOKES
2.0mm (14g) stainless
FRONT TIRE
Specialized Rhythm Lite Control, 26x2.3", 60TPI, aramid bead
REAR TIRE
INNER TUBES
Specialized schraeder valve
SADDLE
Specialized Fuse Lo Pro, 8mm rails, PVC bumpers front and rear
SEATPOST
Specialized alloy two bolt, no offset, micro adjust, 30.9mm
SEAT BINDER
Integrated w/ replaceable single bolt
FRAME
REAR SHOCK
FORK
HEADSET
STEM
HANDLEBARS
GRIPS
FRONT BRAKE
REAR BRAKE
BRAKE LEVERS
FRONT DERAILLEUR
REAR DERAILLEUR
SHIFT LEVERS
CASSETTE
CHAIN
CRANKSET
CHAINRINGS
BOTTOM BRACKET
PEDALS
RIMS
FRONT HUB
REAR HUB
SPOKES
FRONT TIRE
REAR TIRE
INNER TUBES
SADDLE
SEATPOST
SEAT BINDER
