H-DOG
Hey guys, selling ye old DH rig as I'm trying something new. Bike is 6 months old and hasn't been ridden all that much. (Not really a DH'er). The bike is in excellent condition mechanically and only has shuttle scratches+a few paint chips for the cosmetics (The worst being the non-drive side crank arm, slight chips on bashguard). There are no dings/dents or cracks anywhere on the frame and I have tried to take photos of the scratches as best I can. Still in very good condition for a DH rig.
The bike will be given a service and the grips(currently a little torn) will be replaced along with the gear cable, prior to sale. Can also swap the Renthal's back to the Specialized bars which are the same width but have a slightly taller rise if desired.
Any questions or the need for specific photos please ask!
Thanks guys!
Item: 2014 Specialized Demo 8 II Large
Item Condition: Very good, only a few shuttle scratches etc
Reason for selling: Trying something a little different.
Price and price conditions: $4200 ono. PRICE DROP $4050, $3900, $3800! need it gone!
Extra Info: Ohlins is good!
Specs:
FRAME
M5 manipulated alloy, 1.5" forged headtube, 135mm rear spacing, compact race design, magnesium link, ISCG '05 mount, cartridge bearing rear shock mount, rear derailleur protector, 200mm travel
REAR SHOCK
Custom Õhlins TTX22M, coil over w/ piggy back, spherical bearing mount, high/low speed comp, reb adj., 9.5x3.0", Spring Rate XS: 297lb, S:343lb, M:388, L:434lb
FORK
RockShox Boxxer World Cup, Mission Control damper, Solo Air spring, alloy steerer, comp and reb adj. w/ bottom out control, 20mm Maxle DH thru-axle, 200mm travel
HEADSET
1-1/2" integrated for 1-1/8" steerer, cartridge bearings
STEM
Specialized Direct Mount, 6061 alloy, 4-bolt, 31.8mm clamp
HANDLEBARS
Specialized Demo, low-rise, 7050 alloy, 780mm wide, 8-degree backsweep, 6-degree upsweep, 31.8mm or Renthal Fatbar 780mm
GRIPS
Specialized Sip Grip, light lock-on, half-waffle aramid-infused, S/M: regular, L thickness
FRONT BRAKE
Custom Avid Code X0 World Cup, hydraulic disc, Code caliper, organic pad, stainless hardware, 200mm rotor
REAR BRAKE
Custom Avid Code X0 World Cup, hydraulic disc, Code caliper, organic pad, stainless hardware, 180mm rotor
BRAKE LEVERS
Custom Avid Code X0 World Cup, hydraulic disc, X0 lever, tool-less reach
REAR DERAILLEUR
SRAM X0, 9-speed, short cage
SHIFT LEVERS
SRAM X0, 9-speed, carbon/aluminum trigger, w/ MatchMaker clamp
CASSETTE
Shimano HG-70 Capreo, 7-speed, Micro 9-20
CHAIN
KMC X9 SL, nickel plate, reusable Missing Link
CRANKSET
SRAM X0 DH, carbon arms, micro-single 32T ring, PF30 spindle, 165mm, E.13 SRS chainguide
CHAINRINGS
32T
BOTTOM BRACKET
SRAM PF30 DH, 83mm shell
PEDALS
Specialized Bennies, 6061 alloy body, sealed cartridge, 4.5mm removable pins
RIMS
Roval DH 26, alloy disc, 30mm wide w/eyelets, 32h
FRONT HUB
Specialized Hi Lo disc, sealed cartridge bearings, 20mm thru-axle, 32h
REAR HUB
Custom DT Swiss, Capreo compatible, Star Ratchet, 135mm, 32h
SPOKES
DT Competition Stainless, 3X front/rear 2.0
FRONT TIRE
Specialized Butcher DH, 26x2.5", wire bead, soft dual-compound, 60 TPI
REAR TIRE
SADDLE
Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
SEATPOST
Thomson alloy straight w/ 12-degree clamp, 367mm
SEAT BINDER
Specialized 7050 hard anodized alloy, single bolt, 34.9mm
Photos: Why Yes!
Thanks guys!
Specs:
FRAME
REAR SHOCK
FORK
HEADSET
STEM
HANDLEBARS
GRIPS
FRONT BRAKE
REAR BRAKE
BRAKE LEVERS
REAR DERAILLEUR
SHIFT LEVERS
CASSETTE
CHAIN
CRANKSET
CHAINRINGS
32T
BOTTOM BRACKET
PEDALS
RIMS
FRONT HUB
REAR HUB
SPOKES
FRONT TIRE
REAR TIRE
SADDLE
SEATPOST
SEAT BINDER
Photos: Why Yes!
