12mm thru. The 10mm are bolt in, bolt thru and QR. To use them in QR dropouts, all you need is end caps for either 10mm through or QR, bolt up 10mm will need an Axel swap, which is easy.Is the rear hub a bolt in 12mm axel??
would that work for a QR frame?
I've got the end caps for 10mm bolt up that you could have. I have zero use for them.Is the rear hub a bolt in 12mm axel??
if they are 135x10 bolt through caps to suit a pro 2 evo hub, i'll take them.I've got the end caps for 10mm bolt up that you could have. I have zero use for them.
Yeah they be the ones. Come and get em!if they are 135x10 bolt through caps to suit a pro 2 evo hub, i'll take them.
