Item: 2014 Specialized S-Works Stumpjumper FSR EVO 29 Size Small in Silver
Item Condition: Presents immaculately and will be ridden with pride
Reason for selling: Too much time locked in the stable
Hi-Res photos available on request
Extra Info: The cage carries a SWAT bottle with CO2, Tube and tool. Chainbreaker is mounted in the headstem.
Grips are new. Seat is original and new.
Specification: FRAME FACT 9m carbon front triangle, 29" EVO geometry, FACT IS construction, M5 alloy rear triangle, tapered headtube, PF30 BB, ISCG ’05, internal Command Post IR routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 135mm travel SWAT Bottle cage, EMT Tool, and Top Cap Chain Tool w/ SWAT Technology
REAR SHOCK Custom FOX Float CTD Factory w/ AUTOSAG and Boost Valve, Kashima coating, Climb, Trail, Descend settings and reb adj., 195x46mm
FORK RockShox Pike RCT3 29, Solo Air spring, tapered alloy steerer, comp, lockout, reb, and threshold adj., 15mm thru-axle, 140mm travel
HEADSET 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
STEM Syntace F109, 6-degree rise, 31.8mm clamp
HANDLEBARS Specialized XC mini-riser, alloy, 750mm wide, 10mm rise, 8-backsweep, 6-upsweep, 31.8mm
FRONT BRAKE Custom Avid X0 Trail World Cup, 4-piston caliper, steel backed metallic pad, S/M: 180mm, Others: 200mm rotor
REAR BRAKE Custom Avid X0 Trail World Cup, 4-piston caliper, steel backed metallic pad, S/M: 160mm rotor, Others: 180mm rotor
BRAKE LEVERS Custom Avid X0, hydraulic disc, carbon blade w/ bearing, tool-less reach adj. w/ MatchMaker clamp
REAR DERAILLEUR SRAM XX1 Type 2, 11-speed, mid cage
SHIFT LEVERS SRAM XX1, 11-speed, carbon trigger, w/ MatchMaker clamp
CASSETTE SRAM XX1, 11-speed, 10-42
CHAIN SRAM XX1, 11-speed, hollow plates/pins, PowerLink
CRANKSET S-Works OS carbon, custom
SRAM XX1 style chainring, S: 170mm
RIMS Optioned Roval Traverse SL (Carbon) Fattie 29, hookless bead, 30mm internal width
FRONT HUB Roval Traverse SL 29, 15mm thru-axle end caps, 32h
REAR HUB Roval Traverse 29 142+, DT Swiss Star Ratchet, XX1 driver body, 12mm thru-axle, 32h SPOKES DT Swiss Super Comp, 2.0/1.65/1.8 stainless
FRONT TYRE Specialized Butcher Control, 2Bliss Ready, 29x2.3", foldable aramid bead, dual-compound, 60TPI
REAR TYRE Specialized Purgatory Control, 2Bliss Ready, 29x2.3", foldable aramid bead, dual-compound, 60 TPI TUBELESS Setup
SADDLE Body Geometry Henge Expert, Ti rails, 143mm
DROPPER SEATPOST Specialized Command Post IR, 3-position, internally routed adjustable height w/ air spring, remote operated, single bolt head, 30.9mm, S:100mm
Pictures:
Pictures:
