norco01
New(first) road bike comes next week. 2008 specialized allez elite.
I'll have about $150 left after i buy shoes and nicks, was wondering what would be the easiest way to lose a bit of weight.
spec list is here>
STEM
Specialized Comp-Set, 3D forged alloy, 4-bolt 31.8mm bar clamp, 4-position adjustable
HANDLEBARS
Specialized Expert, 6061 alloy, short-reach drop, ergonomic top shaping, 31.8mm
TAPE/GRIPS
Body Geometry Bar Phat, cork ribbon w/ 2.5mm gel padding
FRONT BRAKE
Ultralight dual pivot brakes, Teflon pivots, forged alloy w/ cartridge pads
REAR BRAKE
BRAKE LEVERS
Shimano Tiagra, 9-speed STI
FRONT DERAILLEUR
Shimano Tiagra, 31.8mm clamp, bottom pull
REAR DERAILLEUR
Shimano 105, short cage
SHIFT LEVERS
Shimano Tiagra, 9-speed STI, flight deck compatible
CASSETTE FREEWHEEL
SRAM PG-950, 9-speed 11-28t
CHAIN
Shimano HG73, 9-speed
CRANKSET
Shimano Tiagra, 2-piece crankset
CHAINRINGS
50x34T
BOTTOM BRACKET
Sugino integrated, exterior cartridge bearings, alloy
PEDALS
Composite body, alloy cage w/ toe clips and straps
RIMS
Jalco Dynamics 270, alloy triple wall, machined sidewalls w/ indicator grooves
FRONT HUB
Specialized forged alloy, 24 hole, double sealed bearings, straight pull spokes, QR
REAR HUB
Specialized forged alloy, 28 hole, double sealed bearings, straight pull spokes, cassette, QR
SPOKES
Stainless 14g, straight-pull
FRONT TIRE
Specialized Mondo Pro, 700x23C, aramid bead, 120TPI, Flak Jacket
REAR TIRE
TUBES
Specialized standard presta tube
SADDLE
Specialized Alias, carbon reinforced base, microfiber cover
SEAT POST
Specialized Pavé II, FACT carbon w/ Zertz insert, aluminum head, 27.2mm
SEAT BINDER
Specialized CNC, alloy, 31.8mm clamp
I know wheels should be first on the agenda, but they will be coming at christmas time, so anything in particular i should be looking at in the mean time?
Also, can anyone tell me what this "zertz insert" is i keep seeing?
lewis
spec list is here>
STEM
HANDLEBARS
TAPE/GRIPS
FRONT BRAKE
REAR BRAKE
BRAKE LEVERS
FRONT DERAILLEUR
REAR DERAILLEUR
SHIFT LEVERS
CASSETTE FREEWHEEL
CHAIN
CRANKSET
CHAINRINGS
50x34T
BOTTOM BRACKET
PEDALS
RIMS
FRONT HUB
REAR HUB
SPOKES
FRONT TIRE
REAR TIRE
TUBES
SADDLE
SEAT POST
SEAT BINDER
lewis
