Just thought i'd post something about effective treatment of a snakebike..
Appologies if someone has already posted this, but it never hurts to racap this sort of thing anyway...
before anybody decides to argue with my treatment or question my qualifications, i am an active member within St John Ambulance Australia, i hold certificates in Senior First Aid, Advanced First Aid and Advanced Life Support Procedures and have recently completed an Instructor accreditation course.
First things first, If you are bitten by a snake, any snake (or a funnel web for that matter), Follow the simple DRABCD procedures, hopefully you wont need to work all the way through...
Check for Danger, make sure the snake isn't still around, no point endagering yourself or anyone else any further..
You want to be, or have the casualy lying flat, minimising movement and therefore the flow of the venom through the lymphatic system.
You need to bandage the limb that has been bitten from the bed of the fingernails or toenails, as far up the limb as possible..Tightly, but not so tight that you cut off the circulation (to check for circulation you can squeeze the finger/toenail and watch for capillary return (return of colour to the nail), should be within 2seconds). It's preferable to use a 10cm elastic bandage, but you can use whatever you have. When you bandage the limb, try to remove any clothing that may be on it first, allowing the Pressure and Immobilisation Bandage to do its job properly. keep the clothing to give to the hospital and they can use it to identify the type of snake.
Also if you can, mark the approximate bite point on the outside of the bandage.
Of course, in any situation where you or someone else has been bitten by a snake or venomous spider, call an ambulance immediately (or get someone to do it for you). 000 on a landline or a mobile, or 112 from a mobile.
Hopefully this helps a little, and expands your knowledge shoudl you encounter something of this nature.
