Ride report - worked well on the Lefty. Told me to change.......nothing. Rebound, air spring rate and pressure were all good. Said I should make high speed compression softer, but can’t on that XC racer fork…..my shock pump showed about 180PSI and the Wiz was saying 176-177, pretty happy with that! I'd removed a volume spacer already a couple of years ago, should put it back in and see if it says to remove it....!
Since ive fiddled with the fork for 3 years already, maybe that isn't much of a surprise.
For the rear Fox CTD shock, didn't get to test it for long enough, but need to slow the rebound back a click. Overall - if you are paying $500ish for this on a bike you've already dialed yourself - a massive waste of money. To hire it - good for piece of mind and to play with the toy. I've just got to hire mine out to my mates now....
