lachie.g
hi all, so im getting a new bike in the next week and looking on thoughts of upgrades of spec list etc
so im getting a scott voltage fr10 2011 model heres a pic and spec list, in red are my thoughts of upgrades:
Fork:
Fox 36 Van FIT RC2 coil possibly boxxers in the coming months
shock: fox dhx rc2 vivid air
Rear Derailleur:
SRAM X.9 / short cage
Shifters:
SRAM X.9 / Trigger Shifter
Chainset:
Truvativ Holzfeller DH 1.1 165mm crankarm
Bottom Bracket:
Truvativ HowitzerXR 73mm shell
Cassette:
SRAM CS PG-1050 10 speed / 12-36 T
Front Brake:
Avid Code R Disc with 203mm rotor
Rear Brake:
Brake Levers:
Avid Code R Disc
Handlebars:
Scott Pilot FR 1 Pro / Double butted 20mm rise, 750mm renthal fat bars!
Stem:
Truvativ Hussefelt / Oversize 31.8mm 1 1/8" / 0 degrees angle, 40mm length sunline ??
Headset:
FSA Gravity 2 / Tapered, upper alloy cups 1.5" Reducer to 1 1/8", semi-integrated
Rims:
DT Swiss FR600 / 32H / DH disc rim white
Front Hub:
Scott Pro 20mm thru axle
Rear Hub:
Scott DHL-135 12mm thru axle / 135mm wide
Saddle:
Scott Voltage FR cr-mo rails something less bulkier, zero atom possibly
Seatpost:
Scott DJ zero offset / 31.6mm thompson
Weight:
17.10 kg / 37.67 lbs approx
Fork:
Rear Derailleur:
Shifters:
Chainset:
Bottom Bracket:
Cassette:
Front Brake:
Rear Brake:
Brake Levers:
Avid Code R Disc
Handlebars:
Stem:
Headset:
Rims:
Front Hub:
Rear Hub:
Saddle:
Seatpost:
Weight:
