What year model are they? I'm guessing 05? 05 had a lot of trouble with the pedal inserts coming out.well im not very sure if it's coming off, but there is a slight play.
the threaded bit is slightly off and the little 0-looking thing is a bit out....
is that bad news?
cranks: butterfelts
Consider yourself lucky. If you are able to do that, then the arm is still intact and the insert has just come out. I'm not sure, but you might be able to get a new insert put in...but I don't know.I have the 05's and when taking my pedals off, both sides, the pedal insert comes off still attached to the pedal thread. It doesnt really bother me as they dont come loose when riding ever but if I want to get new pedals or something I may have to use a loctite variant to secure the inserts back into cranks arms then try again.
It was the normal red one. The key to it is to snap down hard on the pedal spanner, otherwise you will just break the loctite.
that's the one i use.
so any specific loctite? or just the normal red one?
