Refitting front wheel
David2406
Blueeeeeeeey's on!
Hi all,
Have only been riding since December. I bought a Giant Talon 29er, which I love to ride. Just wondering if there is a trick to re attaching the front wheel after taking it off. Each time I do it the disc brakes seem to rub on the pads and it takes a bit of moving and jiggling the wheel around to as to make it true. Any suggestions to make it easier would be greatly appreciated.
David
ride_29er
I am assuming it is a quick release? if so make sure the wheel is in the dropouts straight, do this by checking the distance between the tyre/rim and the fork, make sure its even on either side. When doing it up make sure it doesn't move in the dropouts either. hopefully this should work?
The Duckmeister
Has a juicy midrange
Be sure the springs on the QR skewer are around the right way! You'll notice they're somewhat conical; the thin end goes to the axle, the fat end goeas outward, against the ends of the skewer. If they're the wrong way around they'll stop the axle seating properly in the dropouts.
Also, with the bike up the right way on the ground, open the skewer so the wheel can move. Use the weight of the bike to seat it nice & snug on the wheel & tighten the skewer.
smitho
This.
If you've taken the wheel out upside down or on a stand, always open and close the skewer with the wheels on the ground to seat the axle.
Ridenparadise
Or a spring may be bent? Or the brake is loose on the mount?
Hi all,
David
Hope this is not a silly answer: don't lock the quick release too tight. I press the quick release with my palm and there's always a little "pressure mark" that goes away in seconds...
(Giant 29er owner here)
