Gone_4_A_Ride
Banned
thats prob the best stp iv seen!
Damn i was beaten to it!
Yes this is definiatly the best STP's ive ever seen. Almost makes me want to go out and buy one.
awww asif, they are teh sexnot a fan of the green nikes though.
i dont see why not, you've made an amazing bike, all ive done is add new tyres and bars, the rest was all your work. thanks mateCan I take some credit for all this?
no?
ok.
SCORE!i dont see why not, you've made an amazing bike, all ive done is add new tyres and bars, the rest was all your work. thanks mate
yeah she goes alright, yeah the hub has some play if u only finer tighten the whole thing, i just get a 6mm and tighten the axle bolt then clamp it down and bobs ur uncle, but the wheel does sit lop sided still lolSCORE!
Have fun with it man, I put a lot of effort into getting that thing together. How's the front wheel/forks? Any play in the hub? I usually had to tighten the bolts on the non-disc side of the forks after the quick release was tightened, then use the quick release on the other side to get it all tight, cause the axle sunk in too far?
oh dont worry thats still on the way, just getting her painted and same with the bars and the cranks and everything is going on the 250 frame, and itl be done!What happened to the 250 Roney?
Take it to resi!!!
As in, the rim is left of center (towards the disc side?)yeah she goes alright, yeah the hub has some play if u only finer tighten the whole thing, i just get a 6mm and tighten the axle bolt then clamp it down and bobs ur uncle, but the wheel does sit lop sided still lol
yeah towards the left, i was thinkng that, i did it on my other bike worked a treat and i wasAs in, the rim is left of center (towards the disc side?)
Flip the wheel around. You don't need the hub in the proper direction, it might look a bit goofy, but I promise it'll center everything right up.
I know it doesn't make sense, but it worked for me. Remember to swap the tyre round the right way if you care enough.
