tkdbboy
Was just setting up my fork the other week and was wondering how much travel people use up from compressing as hard as they can using their body weight.
Curious to compare setups using fairly replicable scenarios.
How much % of your fork travel do you use when:
Fork travel and body weight would be good bits of info too.
30% / 55% / 80% (Yep sag is pretty high but testing these new settings)
180mm , 80kg
- In sag setup position
- Feet on level ground and compressing your forks with as much force as you can
- Feet on the pedals on level ground and compressing your forks with as much force as you can
180mm , 80kg
