Pikes lower service- Oil to use??
DMan
Are people just using the 0-30w that Rockshox recommend or is there something better?
DMan
Fox gold 20wt
10ml in each leg lower.
Excellent. Thanks.
Just curious why 10ml though when Rockshox recommends 5ml drive side-- 15ml non drive side? Will the extra oil in the drive side do any damage?
JTmofo
XC Enthusiast
Thanks mate. I was reading through the rockshox site for the procedure and they listed "14-Present" with the 5-15 so I thought I'd ask.
All good, better safe than sorry.
I do all my own lower service on my Pikes (had 2 sets over 4 years) and never had any problems with Fox Gold 20wt and 10ml/10ml. I used to go 5ml/15ml until I read the updated oil quantity chart.
TheAzza
Is there a noticeable difference with the Fox Gold? I was going to order some to try, but I still have a shitload of Rockshox oil and won’t bother if it is same/same.
teK--
Pre 2015 stated 5/15ml but the current recommendation is 10/10ml
https://www.google.com.au/url?sa=t&...5CMUQFggdMAA&usg=AOvVaw1zjyTeHJoWNrkvKTIw99zh
Sent from my SM-G955F using Tapatalk
I believe they only updated the recommendation to 10ml per side for 2016-on due to changes in the damper sealhead assembly. Earlier forks still have the '5ml max' warning on the damper side footnut. If on the other hand you have retrofitted the revised 2016-on SKF seals then you can run 10/10. The risk is otherwise blowing out the wiper seal on the damper side.
DMan
All good then as mine are 16s.
rone
This. Always go with the volume written on the footnut over the website volumes information.
ChrisJC
Mine are 2016 (perhaps early 2016) and the drive side plug states 5ml max. So do I stick with 5/15 or go 10/10?
teK--
Easy way to tell is to see if the damper sealhead is the new green coloured SKF seal in which case use 10ml. Otherwise 5ml.
My 2016 had new version seals but the old footnut that said 5ml max.
ChrisJC
OK, thanks for that. I haven't looked, but is the seal head visible without removing the damper?
Cheers
CC
has an accommodating arse
Any good quality synthetic engine oil in the lowers. I use a fully synthetic Penrite HPR 5W40 because that what I use in the Renault...
teK--
Cheers
CC
Yeah it's at the bottom of the stanchion which you will see if you are removing the lowers to do the service.
The Duckmeister
Has a juicy midrange
The main thing about the Fox Gold is that it's quite sticky, so will tend to stay on the various bits it needs to lubricate, rather than drain to the bottom of the fork leg. You won't necessarily notice a huge performance difference, but durability of the fork will improve.
