billymtb
The more time i spend at uni, learning about physics, the more I am confused about why some people preach certain cornering techniques. I'll post a couple examples of what i mean and i hope someone can prove me wrong (so i can actually try and corner better!) or post some alternative ideas.
1). Putting your body over the bike, so you put more weight over the tyres and thus more grip.
This is crazy, the reason you slide out on a trail due to lack of grip is because the friction force acting at the tyres is LESS than the centripetal force required to change your direction and thus make it possible to corner (or to accelerate you as you are changing your velocity direction for those who did/do physics). Putting your weight over the bike does not change this, in theory,
F= (m*v^2)/r, m = mass, F = force, v = velocity and r = radius of turn.
Your mass doesnt change if you put your weight over the bike. Yes, you lean the bike over to be able to turn faster, yes, you are able to lean the bike over further if you shift your weight, but if you dont move your body as you lean the bike further, you will simply pivot at the tyres and fall on your side. This crash is NOT due to loss of grip, the shifting of your body weight (laterally) does not affect grip.
2). weight the outside hand/pedal
i weight the outside pedal and it lets me corner better, i dont know why, i haven't thought about it alot so it would be good if someone can explain this aswell .
weighting the inside grip and weighting the outside pedal just counteract each other, both change lean angle of the bike but if you are able to reach your desired lean angle, i dont see how weighting outside pedal or inside grip will allow for more cornering grip. There is still the same amount of force acting through the tyres, and thats all the tyres care about.
i will add more when i remember what else i want to say
