Our third dual susser, finally complete! (after a couple of months of Sundays)
design:
This bike was designed to a be a more playful DH bike along the lines of a Bottle rocket.
We are trying out a few new ideas with this one, both in terms of manufacturing & bike design.
The use of a linkage is the most obvious new direction.
The advantage of using a linkage is that it gives you much greater freedom in shock positioning & allows for tailored shock rates.
This leverage ratio on this bike moves from a fairly linear rate in the first half of the travel and ramps up in the second half (from memory it gains about 100lb equivalent spring rate by bottom out)
geometry:
cockpit (reach/horizontal distance between the BB & top of head tube):
420mm (16.5 inch)
chain stay :
420mm (16.5 inch) (@ 33% sag) -it's rearward so it's about 390-400mm static
Head angle:
~66.5
(sposed to be 66 but it pulled a little in welding -must set & tack more carefully next time)
spec:
forks: 08 talas 36 RC2
shock: DHX5 air
wheels: hope pro 2/mavic 721
brakes: avid elixir
deraileur: saint
shifter: XT
cassette: XT
cranks: SLX
pedals: fun soljam
bars: fun full on
stem: gusset
headset: FSA pig pro
seat: charge
post: tioga
Matt -for all the help & enthusiasm
more general info & links here:
http://www.rotorburn.com/forums/sho...rburn.com/forums/showthread.php?t=77133[url/]
design:
geometry:
420mm (16.5 inch)
chain stay :
Head angle:
~66.5
spec:
shock: DHX5 air
brakes: avid elixir
deraileur: saint
shifter: XT
cassette: XT
cranks: SLX
pedals: fun soljam
bars: fun full on
stem: gusset
seat: charge
post: tioga
