Bottom headset bearing is the same as standard tapered....1.5"Hey folks.
I want to try a pike on my Trance SX with its wonderful OD2 steerer.
Is it just a case of running a standard tapered steerer fork and then getting a different lower headset bearing??
^ what he said....:third:Lower bearing is the same, it's the upper bearing & everything above it you need to change.
They will be ending up in the FOR SALE section here haha.Like others have said just the top needs to be done. What are your plans for your old fox forks?
Did that on my anthem! It was bittersweet. ...Oh joy.... haha.
That would be my luck. go and buy all the required bits and then find i had one of the mysterious not so OD2 bikes.
I'd be interested if in ok nick mate with stem and top headset.They will be ending up in the FOR SALE section here haha.
They are the 2014 (15 spec talas system and damper) Kashima 160mm --> 140mm CTD Fit.
Yep, most of the 2014 Trances that came with Rockshox fork have a standard taper fork and OD2 stem with a shim.measure first, before you go buy a new stem and bearing etc.
For some reason there are OD2 marked bikes in 2014 that are actually standard tapered. Worth a look (and report back)\
Hint - if you use google search (scope:this site) you can search for terms like OD2 - the search on here has a minimum of 4 characters.
