Santa Cruz have all the details online for the assembly and details of the torque specs - https://www.santacruzbicycles.com/en-AU/node/453
DIYMTB sell Enduro bearings in kits for specific frames which works out quite a bit cheaper than buying them individually, they are also very good to deal with - https://www.diymtb.com.au/displayItems.asp?cid=101
Surprising when I had the bearing replaced on my Norco Range there were not a lot of bike shops that had bearing removal and press kits. Jeremy @ Chainbrain in Dromana has all the tools and may even have the bearings in stock.
Brendan
Brendan
Thanks for the suggestions, I'll try the SC dealer where I purchased another frame new last year (although not a SC) and failing that hit up DIYMTB. I'm not the original owner of the frame.
Can anyone remember the torque spec for SC pivot bearings? I had a Youtube video showing the entire process, but I can't find it. From memory it was something like 2nm on the inner (load bearing) and 6nm on the outer bolts.
At the moment when I do them up to ~1nm they're super crunchy. Anything less than that to get them smooth there's heaps of play.
