Cave Dweller
Thought I would post this incase anyone is looking for a new trainer. The D2R shadow is a magnetic direct trainer with a swing mechanism built in that I have had my eye on for a while.
http://www.youtube.com/watch?v=Q12vTCBvzRY
It is not a very well known trainer but it uses the exact same magnetic direct drive mechanism as the Cyclops Silencer which is much more expensive (approx $900) and does not have a swing base.
http://www.wiggle.co.uk/cycleops-silencer-direct-drive-mag-trainer-wcassette/
I bought mine from Torpedo7 on sale for $370 (they are on sale at least once a month), but you can also get it from Cycling Deal or cycling express
http://www.torpedo7.com.au/products/YDTRMN3SH/title/d2r-shadow-bike-trainer
http://www.cyclingdeal.com.au/buy/d2r-shadow-bike-bicycle-professional-roller-trainer/D2R
https://www.cyclingexpress.com/?lan...2R-Shadow-Trainer---Swing-Version&keyword=d2r
HOWEVER, the D2R has two problems
1. The cassette is only for 10 speed, so those road riders with the current 11speed bikes are out of luck.
2. Without a rear wheel on the trainer there is not anywhere to mount a spoke magnet for ANT+ speed sensor. A trainer without speed is not very useful
But never fear, I took a punt, bought the trainer and fixed both problems.
To fit an 11 speed cassette takes two steps. First, you need to file down the small 1mm step on the rear of a Ultegra 11 speed cassette (this will make it only useful on the trainer, can't use on a bike anymore). Then on the D2R trainer you need to move one non-drive side spacer washer to the drive side and mount two washers between the cassette and frame. This results in the cassette being in a perfect position. I dont need to do any adjustments when switching from rear wheel to direct drive.
To fit an ANT+ speed sensor remove the belt cover, glue/tape/zip tie a magnet to the flywheel. Mount an ANT+ speed sensor to the outside of the belt cover so its tripped by the magnet and bingo, you have speed on a direct drive trainer.
If you already have a crank based power meter then you have everything you need to do speed, cadence and power based interval training.
