AM Mega Murmur
Wake Jake
Chosen to go down the simplified path for something different. Steel and two bearings. XXL in all it's glory. First frame out of the factory now it's all made in the UK. Frame/shock snuck through customs so no duties;)
Customer service was impressive and accommodating.
XXL Starling Mega Murmur
EXT Storia V3 w/ 525lb from Mojo
Trail shock length 140mm travel
Intend Edge 160mm
E13 TRS carbon wheelset
SRAM GX AXS
OneUp 240mm dropper
SQLab 612 saddle
Hope Tech4 X2
TRP R1 Rotors
Praxis Works Cadet cranks
Ochain
HT X2 pedals
Protaper 30mm stem
Ergotec 80mm 12° bars
ESI Foam grips
Schwalbe Nobby Nic/Rock Razor
Weight - 17.15kg
Only changes to come are a black chain, shorter cranks and new rotors. Had a little rip on it tonight and boy does it ride well, pedals miles better than I thought it would.
ausdb
Being who he is
Whats the go with the head tube gusset? Did forget to weld it? ;)
I think these are fillet brazed not TIG welded, by the looks of the main tube joints. If that's the case then the gussets could look like that if they are brazed on with most of the braze on the other side.
@Wake Jake can you confirm?
Edit, confirmed fillet brazed, sorry for going OT but its interesting to see how his setup has grown since 2016.
To now.
dirtdad
Love it. Totes jelly. I reached out to the Starling guys before I bought my Banshee. I like that their rear triangle is steel as well. Still sits in my head nagging me.
Keen to read a ride report once you get on it in anger.
wkkie
It's Not Easy Being Green
Looking good! Nothing like the feel of steel.
What can you bump the travel up to with another sized shock?
ashes_mtb
Has preferences
Looks absolutely mint.
Derailleur hangar on the left with the disc brake tabs is an innovation I haven’t seen before!
Out of curiosity, are they a UDH hangar?
