Item: Manitou Mattoc Pro 140mm 27.5+/29 48mm offset
Item Condition: Excellent
Reason for selling: Went slightly more travel with Mezzers
Price and price conditions: $600 +shipping
Extra Info: Exceptional fork that eats small bumps for breakfast and drastically reduces arm pump. The MC2 damper and Dorado Air Spring for an incredible combo.
Infinite Rate Tune (IRT) allows the rider to control mid-stroke rate independent from bottom-out. The closest thing available to the feel of a perfectly chosen coil spring without additional weight.
The fork features:
Suspension travel: 120 mm (adjustable 120-140mm)
Spring: Dorado Air
Bottom out control: Hydraulic Bottom Out, Rubber Bumper
Shaft: 1.5 "Taper Only
Crown: Deep-Hollow Forged Aluminum
Offset: 48 mm
Pressure level: MC²
Rebound: Adjustable TPC (Twin Piston Chamber) Cartridge
Setting options: low-speed compression, high-speed compression, hydraulic bottom out, rebound, beginning-stroke pressure, middle / end-stroke pressure
Standpipe diameter: 34 mm
Standpipe material: 7050 Butted Aluminum
Tire size: 27.5 + / 29 "
Brake standard: Post Mount 180mm
Axis: Hexlock SL 15mm
Crown-to-Axle: 509mm (27.5 + / 29 "100mm travel); 529mm(27.5 + / 29" 120mm travel)
Steerer is 220mm
Pictures:
The fork features:
Spring: Dorado Air
Offset: 48 mm
Pressure level: MC²
Steerer is 220mm
Pictures:
