Recommended is half charge on Lithiums I believe.Hi guys with daylight savings now about its time to pack up the lights till next year and was just wondering weather it's best to charge the battery's before packing them away pack as they are or weather to run the battery's flat? Or does it make no difference
You should never run batteries flat. I read that somewhere on the Cygolite website.Hi guys with daylight savings now about its time to pack up the lights till next year and was just wondering weather it's best to charge the battery's before packing them away pack as they are or weather to run the battery's flat? Or does it make no difference
Half charge at a minimum.Recommended is half charge on Lithiums I believe.
Glad you said that. I've never been arsed to try and work out how I'd know if my batteries were half charged apart from run them on constant from full to flat, and then run them on constant for half that time again, and then store them. That sounds like way too much work.Half charge at a minimum.
Fill 'em up then put them away. That's what i'll be doing.
^^^^ThisLupine recommend storing them in the fridge.
Mate is an electronics engineer working in the UPS industry. His advice is store in fridge at 40-50% charge (NOT fully charged as chemical oxidation = degradation is highest) and is industry best practice.^^^^This
Magic shine also recommends keeping the batteries in the fridge
Good link.Lithium based will self discharge, more so if they're hotter. If you're leaving them out I'd probably fully charge them so there is more of a buffer time before they go completely flat. If you're putting them in the fridge then half charge is probably OK.
This is good:
http://batteryuniversity.com/
As the table shows, at every temp other than zero you loose significant recoverable capacity charging to 100% rather than 40% (and thats based on one year storage so an annual battery maintenance is hardly a major impost).It's just my two cents. If you're going to leave them, possibly forget about them for a long time, they will self discharge more quickly when they're warm which is why I mentioned buffer time. I'd rather have them more charged than best practice than have them completely discharged for a long time which will definitely kill them. I guess it depends how much spare time you have for battery maintenance.
