teK--
Thanks I always clean rim with isoprop thoroughly with a clean shop towel and let it evaporate before putting the tape on. I even wear latex gloves to avoid getting body oils on the tape. The first time I fitted up these wheels I fitted tubes overnight and although the tape lasted maybe 3 tyre changes (rather than 2) it still peeled. So I don't bother with the tube now.Clean your rims thoroughly with isopropyl.
Instal stans tape.
Leave overnight with a tube in to press it down.
Enjoy edges staying where they should and easy removal later without the residue of gorilla......
Also... buy the eBay "can't believe it's not Stans"
Buy 2 rolls to save shipping... never buy tape again (unless you have stingy mates)
http://www.ebay.com.au/itm/Tubeless...076?pt=LH_DefaultDomain_0&hash=item23529a404c
http://www.ebay.com.au/itm/Tesa-4289-No-Tubes-Tubeless-Rim-Tape-19mm-Wide-x-66M-long-/252017199959?
Am already using the Tesa 4289 tape scored a 55M roll for $25 .
Thin as in, narrower than 25mm? I wonder if having tape only in the spoke bed area rather than up on the tyre bead seat area would help.I used the thin stans tape and it worked a treat. Had to be careful to get the tap over the spoke holes in the rim, took 2 mins to do and they pumped up with a floor pump with zero effort. Easiest tubeless I've done, by a mile.
Also, had to get longer stans valves.
Yeah I go about 4-5" overlap at the valve hole. The tyres pop off the rim by hand I only need to get a lever slightly under one bead to get it over the rim (without having to lever against the rim tape). pretty sure it's as the tyre slips into the spoke bed that it pulls the edge of the tape with it :yell:.Stans tape shouldn't come up at the edges Tek - possible problems : rim needs to be really clean before application, and application needs to be tight with a good long overlay ( twice round wouldn't hurt), and final possible, is possible use of tire levers to remove is lifting ( shouldn't use levers if at all possible)
That said , I have read before that carbon prefers gorilla rather than stans in terms of stickiness of the adhesive. Not personally had problem with either type of tape
Stans/Tesa doesn't doesn't feel like it has much stickiness to carbon rims.
I'm going to try, running the 25mm tape along one side of the rim with 2-3mm extending up the sides, and then run another strip against the over side, so both strips overlap the spoke holes in the middle by a good 15mm or so. Then squash the shit out of it with a tube overnight.
Unless someone can find me 34-36mm wide tape so I can do it in one strip?
