trailsnail
I agree with SummitFever here, also the same theory can be used on the drive side for a rear wheel to prevent spokes shifting towards the derailleur.Ideally, for a disc wheel you want the outside spokes to pull tight when you apply the brakes. This arose from an initial concern amongst wheel builders that if the spokes went slack under braking they could bow outwards and get hooked up on the calliper. Having said that, many disc wheels are built the other way without problem.
If you are building your own wheels then chances are you will be sold DT Swiss spokes.
If you are going to buy these I would reccomend that you buy a set of spoke washers to go inbetween your spoke head and hub flange.
A few years back DT changed their spokes to a larger elbow length to allow easier builds for machine built wheels, they did shorten this distance since then, but not all the way back to what a hand build wheel should have.
Using spoke washers will stop the bend on the elbow from straightening out and the short straight section of the elbow from bending.
Overall this will create a longer lasting wheel build with alot less retensioning required over the wheels life.
Also I would suggest just using the brass nipples, alot of aluminum nipples struggle to get proper tension.
I feel a properly tensioned wheel will be faster than one with not enough tension but slightly less rotating mass.
Always bed in your spokes, you can do the crank arm thing like on sheldon browns web page or you can walk on the spokes with the wheel on it's side.
I think a combo of the two works well.
bed in your spokes before you add your higher tension to your spokes and your nipples will stay looking fresh.
Lube the threads and where the nipple meets your rim, some people say this can loosen, I think this is not a problem unless you have skipped the bedding in process and not used spoke washers. a correctly built wheel needs little maintence.
I was 4 years in on a set of street wheels, I had retensioned them once and always abused these wheels.
they were still as strong as the day they were built.
I have since changed them as I now run 20mm front and 14mm rear axels.
