It noticeably better, straight away.Improving the touch performance will be most welcomed.
Try Raw - Off , Wind -On.Ok so set sound to Auto to try and reduce wind noise - its hopeless the microphones are literally turned off / greatly reduced as soon as you get any kind of wind noise or what it thinks is wind noise - will be just trying to get better wind noise reduction from dead cats of some kind - looking at ordering some foam ones that go over the whole camera but they are only in China and say delivery from Nov - Feb
Friggin expensive for the real dead cats.I’m thinking I don’t have big enough moustache and mo hawk on it - will replace them and try again with raw off and wind on - have to record all of today’s video again anyway now
Yeah I’m going to get that but they seem to be only available from China currently and will take up to February to getGet one of these, makes a big difference. That and use the stereo mic setting with it in combination, the "wind" mic sounds terrible regardless.
Just copy the settings, VIC moustaches may have covid... fuck that shit off, its got a 72hr life... beers are the answer.Just wanted to say you guys are great, a wealth of info and I finally have use for the left over packet of moustaches I've been draggin around victoria for the past 10 years.
Curious, when I grabbed the 9 it was very obviously heavier. I wouldn't have picked the difference to be only 12g.32g heavier than the 8.
7 - 116g
8- 126g
9 - 158g
You still have to use the surround on the 7 which takes it to 146g, only 12g short of the 9 and probably not far from the same size.
8 & 9 have the metal tabs built in and the front screen on the 9 is nice addition over the 8.
A bigger battery seems to have made the most difference to weight and size.
I don't notice as I predominantly use a chesty.
Didn't know myself, just grabbed some specs as I was interested in the difference. I've had them all apart for the 4 and 7.Curious, when I grabbed the 9 it was very obviously heavier. I wouldn't have picked the difference to be only 12g.
Like pedals, I suppose.Curious, when I grabbed the 9 it was very obviously heavier. I wouldn't have picked the difference to be only 12g.
I've got a full foam cover for my 9, but if you stick another dead cat over the mic drain on the side you should nearly eliminate all wind noiseTry Raw - Off , Wind -On.
I have 2 of those bits of moustache fluff still stuck on the camera, looks like little Hitler moustache and a mohawk. The runs I posted in another thread at the weekend were with the raw-off and wind-on.
You can still hear a bit of wind but mostly trail noise. The audio is clear at the 2 minute mark, even while moving.
