pharmaboy
To the technical gurus out there, I have a 5month old hope pro ii rear which is laced to crests, gears have been playing up a bit and difficult to change up the cassette (up as in going to easier gearing). I was changing the cassette over to a new one in perpetration for the Scott and when I eventually got the thing off, there was side to side play in the free hub body - about 1 mm at a guess.
So the question becomes whether pulling it apart and putting it back together might fix it, or of it will need a new hub body , or if it caused by worn bearings / something else?
Given the timescale I'm not sure if I will be able to get a hub body before time (weekend after next)- any input greatly appreciated
